04-20-2020 12:00 PM in
Galaxy Noteunable to connect samsung note 10 with sony TV through NFC. While connecting, it asks - complete action using "New tag scanned". After clicking it, phone displays two tags:
(1) vnd.android.nfc://ext/sony.com:wfp2p
(2) vnd.android.nfc://ext/sony.com:wt
Nothing happens thereafter and TV times out waiting for the connection
- Tags:
- nfc
- Note10 Lite
- sony
04-20-2020 12:03 PM in
Galaxy Notelet me remind you that after android 10 android beaming has been discontinued
04-20-2020 12:04 PM in
Galaxy Notealso can you post some camera ui , video ui , and camera setting here along with Bixby routines please
04-20-2020 12:06 PM in
Galaxy Note- Mark as New
04-20-2020 12:08 PM in
Galaxy Noteno
04-20-2020 12:10 PM in
04-20-2020 12:14 PM in
Galaxy Notebro the problem is that in android 10 the android beam has been discontinued if you have s10 then go to nfc setting you won't find any android beam, the sony tv does not requires and special app to get connected with nfc , but the problem is that there is absence of android beam you can clearly see that
04-20-2020 12:16 PM in
Galaxy Notethere is no need for any special app for that the connection can happen with or without any app through android beam but the thing is android beam is no longer present so the connection is not possible
Galaxy NoteAndroid beam is still visible in NFC settings
04-20-2020 12:17 PM in
Galaxy NoteIn my Note10 Lite, it shows both NFC and Android beam options to turn on/off
