Resolved! Solved
Does anyone facing same issue in note 10+
(Topic created on: 04-23-2020 09:38 PM)
Sgrover
Galaxy Note
Hi everyone... I am using note 10+ and noticed one issue. If I enabled wifi calling& my handset also connected with wifi then I am not able to record phone calls.
Please let me know if someone is facing same problem.
Not applicable
Galaxy Note
sir..if I gave you solution then please click on 3 DOTS of my comment and accept my solution 👍👍
13 Comments
Not applicable
Galaxy Note
it's not any issue...call record not supported for wifi calling...it's supports normal phone call only.same for all
Sgrover
Galaxy Note
thanks 😊
Not applicable
Galaxy Note
Not applicable
Galaxy Note
lol don't ask for the solution users don't know about this feature I could also have demanded the three-dot menu but I didn't, don't degrade the quality of experts
Not applicable
Galaxy Note
its not issue sir, the wifi calling does not supports the call recording feature
Chandan9873
Galaxy Note
hi My phone is A50s and my WiFi calling turns off automatically. can someone please help
Not applicable
Galaxy Note
server error with your network
hedgehog
Galaxy Note
reset network settings
Chandan9873
Galaxy Note
thank you guys. it worked
