Charging speed very slow in Note 10+
(Topic created on: 04-17-2021 10:56 AM)
manojkraj85
Galaxy Note
I am facing very slow charging speed in my Note 10 plus. It is taking more than 2 hr to 100% battery charging.  Is anyone facing same issue ??
11 Comments
zaid0786
Galaxy Note
1. Are you using the original charger and data cable .
2. Check that is it charging fast or not if not then you have to change the charger and data cable .
Galaxy Note
Change the charging cable and update the phone software at samsung store
manojkraj85
Galaxy Note
It is Galaxy Note 10+ not Mi
manojkraj85
Galaxy Note
Yes, I am using original charger & cable with 25 w. While charging it is showing super fast charging
døpedædə
Galaxy Note
Bro its normal in summers... due to hot room temperatures
zaid0786
Galaxy Note
No bro it is your wrong theory
døpedædə
Galaxy Note
Its correct bro... tried nd tested hh... practically tested kra h mene ye...
Dilli
Galaxy Note
Charge in a cool place with temp around 25 degrees C
manojkraj85
Galaxy Note
Thanks to all for your suggestion, will act on ur suggestions 😊
