Uvsalaria
11-26-2018 09:02 AM (Last edited 03-15-2019 07:59 PM ) in
Galaxy Note
I am using Note 8 and it is showing the charging status as cable charging instead of fast charging. I used to face this kind of issues earlier as well but it usually went away by just reinserting the charging cable but today it remains same even after reconnecting the charging multiple time.
13 Comments
- « Previous
- 1
- 2
- Next »
Not applicable
11-26-2018 12:46 PM in
Galaxy Note
Try changing the usb cable you use it can be damaged and might have stopped this
NishitMehta
11-26-2018 01:21 PM in
Galaxy Note
You Are Having Cable or Adapter Issue Please Check it With Service Center With Another Cable And Adapter it is working or not At least You Will Know What is the Issue
Khanvd
11-28-2018 12:06 AM in
Galaxy Note
your cable doesn't support fast charge
admin_
11-28-2018 04:46 PM in
Galaxy Note
Thank you for being with Samsung and sharing your concern. We would like to offer some troubleshooting steps to overcome the issue:
1) Kindly use fast charging cable and enable fast charging by navigating to Settings >> Device Maintenance >> Battery >> Tap on three dots >> Advanced Settings.
2) Reset the device settings by navigating to Settings >> General Management >> Reset >> Reset Settings.
3) Check the issue in Safe Mode.
4) Keep updating the device via FOTA or Smart Switch.
5) Take full data backup and reset the device.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
- « Previous
- 1
- 2
- Next »
