Battery problem
(Topic created on: 01-23-2021 08:44 AM)
Raja1989
Galaxy Note
I am not getting one day battery life could you please provide me a tip or suggestion to improve battery
6 Comments
RushabhShah
Galaxy Note
uninstall all the apps which you are not using.
Sleep the apps which you are rarely using.
if your smartphone has higher refresh rate then start using adpative refresh rate or bring it to 60Hz
and use dark mode to save more battery.
and one more thing is to use your smartphone in adaptive power saving mode.
if you like my comment please click on three dots and click on solution.
Pratma
Beginner Level 4
Galaxy Note
Hello Raja1989. If you are facing any kind of battery issues, I'd suggest you to check the battery usage statistics in the device care tab and look for the apps having high battery consumption. If possible restrict the apps having high battery usage from having any kind of bavkground activity. This will help.
Vrang
Galaxy Note
Open device care and go to battery section and enable adaptive power saving and also you can select which apps to sleep and deep sleep as there will be many apps which we don't use daily
00o
Galaxy Note
device?
Ehsank
Galaxy Note
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
