Battery problem after an update
(Topic created on: 04-27-2019 07:57 AM)
VanWilder
Galaxy Note
I have Note8, battery work better but when it reaches to 15% then with a minute it goes to 0% and I'm facing this issue after an update Is any one else is having this problem.and whats the resolution for it?
4 Comments
pandey18
Galaxy Note
use code *#0228# and reset your fuel gauge after that drain down your battery to 0 and charge it to 100 on off status .. I hope it I'll fix it
VanWilder
Galaxy Note
I request can you explain what exactly its gonna do?
pandey18
Galaxy Note
it will reset your battery count gauge and if your battery is in good state it will fix it
haridasyadav
Galaxy Note
yes
