Battery drainage problem in note 10 plus
(Topic created on: 05-23-2020 11:24 PM)
Aman0902
Galaxy Note
Hello All , i have recently bought a note 10 plus in this January and after using it for 4 months i m facing a problem of sudden battery drainage when it is at 18 percent or a little bit low... It itself switches off and battery drains to zero... i have made all the necessary settings nd have kept my phone on optimized battery usuage from the very first day... Also i am not having any excess of apps installed in my phone... Just want to ask is this everyone here facing this issue and have wasted such much of money on this **bleep** or i m the only one.... please suggest the possible reasons and solution for this..... Really disappointed... 😔😔
4 Comments
batking33
Galaxy Note
yes same phone here..... we have battery optimized issue for sure. . but haven't faced issue similar to yours ..... have you tried to wipe cache partition on your phone?
Dilli
Galaxy Note
Your phone is in warranty so when Samsung service center opens go and thrash out with them.
cs_member10
Galaxy Note
Dear Samsung Member,
To resolve "Battery drainage" issue kindly follow the given below steps:
1)Battery optimization:-Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
2) Close background running apps:-Tap on recent key and close the background running application.
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
lethusha
Galaxy Note
Over night battery drainage issue
Marginal battery drainage understand by optimize mode, i am goes to sleep after changing my phone to hundred percent & after 6-7 hours sleep ,i would wake up to only 92-91 charge on my phone even using power mode , I don't know how to fix that bug
As well we can fully use the phone to o% battery ,then fullly chage your phone ,after that factory reset the phone 🤔 most of the people said thats is correct method
