09-23-2020 11:24 AM in
Galaxy Note- Mark as New
09-23-2020 11:35 AM in
09-23-2020 12:12 PM (Last edited 09-23-2020 12:12 PM ) in
Galaxy Note2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
09-23-2020 12:13 PM in
Galaxy Note3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder.
6. If you use Facebook frequently then disable "auto play video"
And if you are mostly uses mobile on wifi connection then also disable "auto play videos" in YouTube.
09-23-2020 05:04 PM in
09-23-2020 05:14 PM in
09-23-2020 12:15 PM in
09-23-2020 01:30 PM in
09-24-2020 07:44 PM in
09-24-2020 05:19 PM in
Galaxy NoteDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
