Note20 Ultra battery drain after December update
(Topic created on: 12-17-2023 12:44 PM)
Aditya_Anurag
Galaxy Note
After updating to Dec patch 2 days ago, my battery is not even lasting half a day and this is only 1 year old battery.
Is anyone else facing this issue?
cs_member10
Galaxy Note
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
