Battery drain issue on Note5
(Topic created on: 01-12-2017 12:30 PM)
Yogie09
Galaxy Note
Since last update battery drains so fast. Screen taking too much of battery power. my phone is set to all optimum settings & even tried your provided solution http://www.samsung.com/in/support/skp/faq/448003 but in vain.66b693ab-d9e1-42e8-ad64-65b4bc361636.jpg
8 Comments
saurav
Galaxy Note
try reducing screen brightness...my battery lasts way longer when i reduce screen brightness...i usually keep the brightness a little above the lowest level
Samsung_India_
Galaxy Note
Thank you for sharing your concern. Kindly maintain the brightness level of device low as per you convenient. Still issue persist We would suggest you to visit nearby Samsung Service Centre so service engineer will examine your device physically. Please find service centre details in the link provided http://www.samsung.com/in/support/servicelocation.
Yogie09
Galaxy Note
Brightness is set to auto (default settings). I've been using my Note5 almost one and half year now with default factory settings but never faced this issue before. I owned Note3 too so I'm not less familiar or have less knowledge about Android & its related tweaks & tricks.
So please come up with the proper solution.
mahendra
Galaxy Note
sir note8 me kya s secure nahi ahat kya
mahendra
Galaxy Note
or primiyam phone lene ka koi matlab nahi he usse to a6a a series achi he
mahendra
Galaxy Note
of redio bhi nahi ata
mahendra
Galaxy Note
or my galaxy weights bhi nahi ata
mahendra
Galaxy Note
bhai note 8 me pie ka update kab ane vala he
