Battery Problem
(Topic created on: 06-01-2019 07:44 AM)
amitagrawaldhl
Galaxy Note
After update,
While charging battery gets stucks at 83%,
Anyone facing same issue ??
4 Comments
Navedyousuf
Galaxy Note
yup...you have to unplug and then plug again
Galaxy Note
still....after 83/84, it doesnt move up
saggu
Galaxy Note
try factory reset
Galaxy Note
were u facing the same problem ? and did it solved by factory reset
