12-05-2021 12:30 PM in
Galaxy Note- Mark as New
12-05-2021 12:35 PM (Last edited 12-05-2021 12:36 PM ) in
Galaxy Note1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Credit-Ehsank
12-05-2021 12:36 PM in
Galaxy NoteA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect with pc/laptop or type c earphone only for Android 11 )
...........OR.......
IF YOU HAVE ANOTHER MOBILE THEN CONNECT WITH CABLE WHETHER IT IS TYPE C TO TYPE C OR MICRO USB PORT take help of otg connector to connect with other mobile.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
If still same issue persist then try these below steps
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
(NOTE : Reset settings/ Reset App preferences, change all settings to default)
12-05-2021 01:23 PM in
12-05-2021 03:00 PM in
Galaxy Noteand motion smoothness??
12-05-2021 03:03 PM in
12-12-2021 06:14 PM in
Galaxy NoteDear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
