Finaly i found solution for BGMI lag/fram drom in note 20 ultra
(Topic created on: 11-13-2021 09:10 AM)
AawidKhan
Galaxy Note
this solution for Note 20 ultra exynos varient.
if you face lag or frame drom while olaying PUB/BGMI then do as follow-
Go to Setting - Battery and device care- Battery- More Battery setting - On Enhanced Processing
Note- Run game from out side of game launcher.
your problem will be solve.
6 Comments
Galaxy Note
No you're mistaken.
Enhanced processing has nothing to do in gaming.
Galaxy Note
Yah 😆
Its clearly written !!
Galaxy Note
Yup
AawidKhan
Galaxy Note
you are right when you open game from game launcher then not effective. but if you open game from outside of game launcher then game threated as normal app not game. so this time it will be effective. i had laging/frame drop problem while i was playing BGMI and i've try everything but not solved and when i did this then gameplay is suorbbb smooth.
try bro then you relize that its wrking.
Galaxy Note
I think the smartphone knows how game and normal app perform ?
Well if by doing so your problem solved then it's really good.😃
AawidKhan
Galaxy Note
i've posted just solution and its working.😉
