Battery Drain
(Topic created on: 12-25-2020 01:00 PM)
Rohilsykes
Galaxy Note
Anybody else facing issues with their batteries on their Note 20 Ultra? Mine doesn't seem to last me even 4-5 hours of SOT with normal usage. Disappointed, honestly.
3 Comments
Not applicable
Galaxy Note
how they can ..
if you simply use mobile data or wifi to install software in Samsung device then this will happened only ..Samsung provides non A/B partition type ota software not like other company hence the recommended process to install software is via smart switch and pc or via Samsung service center firmware flash otherwise possible software loop hole can create anything mysterious with device....not only battery drain,, display and motherboard can gone forever as many many users faced before
Ehsank
Galaxy Note
you can do these settings and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
