Battery Drain + Slow Processing
(Topic created on: 03-03-2021 03:12 PM)
Rachitjain25029
Galaxy Note
I am Using Galaxy Note Series phone very much it is very good series but after update firmware one ui 3.0 its getting problem faced ( battery drained + Slow processing during calling) .... kindly update firmware and resolve this problem.....
Regards:
Rachit
5 Comments
Ehsank
Galaxy Note
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect with pc/laptop or type c earphone only for Android 11 )
...........OR.......
IF YOU HAVE ANOTHER MOBILE THEN CONNECT WITH CABLE WHETHER IT IS TYPE C TO TYPE C OR MICRO USB PORT take help of otg connector to connect with other mobile.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Galaxy Note
it will wipe all data
kapilmalik
Galaxy Note
Hi Rachit, your observation is right. since the update to Android 11 and UI 3.0, Note 10 Plus has developed calling issues and battery draining out fast. calling issues are indeed erratic..
Galaxy Note
really true
Galaxy Note
really true
