Anyone else facing huge battery drain issues after July 2022 latest update
(Topic created on: 07-27-2022 05:23 PM)
UDeo
Galaxy Note
I am facing the issue of quite fast battery drain in my Galaxy Note 10, post the latest July 2022 update. Any suggestions?
3 Comments
Babayaga575
Galaxy Note
In april security patch my note 10 plus battery was draining so fast after june it got fixed and now july again battery issue is starting
But not like april security patch
Arun_Cyriac
Galaxy Note
Yes . Same issue facing for Note 20 Ultra also. Battery is draining without any reason. And hardly 6-7 hours i am getting now. Earlier 11-12 hours it use to run with a full charge
cs_member8
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
