Speaker problem sound issues 😭
(Topic created on: 07-11-2024 08:46 PM)
SSVG
Galaxy M
Sound stops suddenly while playing videos
It is happening frequently
8 Comments
MR_PRIME
Galaxy M
Last you will have to do that is Factory data reset because that's only the last option. After that if problem is still there then it's hardware related issue.
Plz Accept solution clicking on 3dot right side nd Do follow for Regular Updates.
SSVG
Galaxy M
It's already done but issue exists
MR_PRIME
Galaxy M
Do one last thing go to Samsung member app and dignostic option where click on speaker section and check that's last the hope otherwise that would be hardware issue.
SSVG
Galaxy M
It's also done just before posting this issue but it occurs often
MR_PRIME
Galaxy M
Then it's hardware issue buddy you will have to visit service center they will check our may change your speaker.
SSVG
Galaxy M
Yes 👍
cs_member10
Galaxy M
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
nike777
Galaxy M
Speaker low sound problem
