01-08-2025 12:52 AM in
Galaxy M- Mark as New
01-08-2025 08:11 AM in
Galaxy MPotential Causes
1. *Faulty charging port*: Dirt, dust, or corrosion in the charging port might be preventing the original cable and adapter from working.
2. *Software issue*: A software glitch or bug could be causing the charging problem.
3. *Power management issue*: The phone's power management system might be malfunctioning, preventing charging.
4. *Hardware failure*: A hardware component, such as the charging IC, might be faulty.
Troubleshooting Steps
1. *Clean the charging port*: Use a soft brush or a cotton swab to gently clean the charging port.
2. *Restart your phone*: Sometimes, a simple reboot can resolve software issues.
3. *Check for software updates*: Ensure your phone is running the latest software version.
4. *Boot in Safe Mode*: Restart your phone in Safe Mode to isolate any third-party app issues.
5. *Reset charging settings*: Go to Settings > Battery and device care > Advanced > Reset charging settings.
6. *Try a different wall outlet*: Rule out any issues with the wall outlet or electrical supply.
7. *Visit a Samsung authorized service center*: If none of the above steps resolve the issue, it's possible that there's a hardware problem. Visit a Samsung authorized service center for further assistance.
Additional Tips
1. *Use the original cable and adapter*: Try to use the original cable and adapter to rule out any compatibility issues.
2. *Check the cable and adapter for damage*: Inspect the original cable and adapter for any signs of damage or wear.
3. *Keep your phone's software up-to-date*: Regularly update your phone's software to ensure you have the latest security patches and features.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-08-2025 09:06 AM in
Galaxy MDear Samsung Member,
● Check connectivity & charger functionality: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
● Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
Note: Kindly open Device Care from Settings > Battery > Please tap on 3dots (more option) at the top right-hand side > Please select settings> Enable fast cable charging.
● Kindly disable the battery protection mode( if enabled).
● Kindly follow the standard charging procedure. Charge the device in switch-off condition for a minimum of 10 minutes.
● Please check the back panel of your device's physical condition (Bulge, Swelling, or visible damage).
● If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper with the battery also request you to visit the service center immediately.
01-08-2025 01:31 PM in
01-08-2025 03:29 PM in
Galaxy M
