Resolved! Solved
Samsung M30s Fast charging issue... solution
(Topic created on: 07-24-2020 12:07 PM)
Kishore9
Galaxy M
finally I'm saying who are facing these problem on m30s fast charging issue after July security patch level update if you need to urgent Simply go to Samsung service center and just install new softare then the problem is solved or if you don't need now just waiting for next Month Software update just update via pc in Samsung smart switch then the problem is solved.
These two options is there above problem and there is no chances to anything.
Resolved!
24 Comments
Kishore9
Galaxy M
bro I already checked temperature and original charger my another mobile charger A50 but no use
Kishore9
Galaxy M
bro some people are told facing same problem many of users Saying this, and finally yesterday i went Samsung service center i update software also but no use, bro it's completely software bug bro.
Kishore9
Galaxy M
bro I'm trying all basical things but no use. many of M series users are saying Samsung members App about charging issue only after July update..
Kishore9
Galaxy M
bro Samsung service center team told replace charging port and they return to back mobile after 20 days. listen bro my mobile is new and these problem facing many of users so Samsung team how can I tell Saying replace port I told Samsung team many of users facing these problem they are told simply I don't know. is it right answer, they don't have idea about this problem just they are experiment customers mobile this is not old phone and these problem facing several users. I think these problem rectified August security patch level update.
Not applicable
Galaxy M
I oppose this cause my mobile is 7months old not a new one. But I don't have this issue. Many users who have this problem didn't went to service center to say if its a software issue. Maybe they are correct replacing port may help. But 20days is long wait. Try others service center too..
