Resolved! Solved
Samsung M30s Fast charging issue... solution
(Topic created on: 07-24-2020 12:07 PM)
Kishore9
Galaxy M
finally I'm saying who are facing these problem on m30s fast charging issue after July security patch level update if you need to urgent Simply go to Samsung service center and just install new softare then the problem is solved or if you don't need now just waiting for next Month Software update just update via pc in Samsung smart switch then the problem is solved.
These two options is there above problem and there is no chances to anything.
Resolved!
Kishore9
Galaxy M
bro I just update software in Samsung service center M30s mobile but fast charging problem is not solved. still problem is there, and they are told try to change charging port they are do in hardware section, Samsung service center team don't know solving the problems, they just experiment new mobiles from customers waste of time & this is not only my problem many M30s users facing these issue I'm telling this in service center they are told I don't know. so how these people told like replace charging port? anyway what's the solution bro, bro it's completely july month security patch level update bug because I'm update software in Samsung service center but still I'm facing these problem.
Kishore9
Galaxy M
bro what's the your opinion or solution about M30S fast charging issue.
Not applicable
Galaxy M
see service center did ultimate job ..because firmware already reflashed and refreshed ....but if still your device suffering that ..then it's better to check device charging port or charger or wait for next security patch update..let's see what is happening....why saying because other m30s users flashed it by same process no such issue present in their devices except DRM issue of Netflix HD. and that is built-in software fault which will be fixed in next security patch update....🙂
Not applicable
Galaxy M
Kishore bro, my M30s takes 2hrs 20min for 100% in fast charge and 2hrs 40min in cable charge.. As you can see in your recent post users commented don't have issues. So I suggest to replace charger. And check temp of device while charging. Generally charging speed decreases when temp is above 38°C.
SamsungUser11
Galaxy M
how big is the update
Kishore9
Galaxy M
bro visit your nearest Samsung service center just you say update Software. and your mobile is now running warranty period the Software update service is free of cost, there is no charges. I think up to know today date all Samsung m30s devices is now running in warranty period in India because the mobile launching date is September 2019. so just visit Samsung service center, after then please tell me. how your device working like good performance.
Kishore9
Galaxy M
if possible.....then you can click 3 dots of my comments of your previous post and accept my solution, it's also rules in Samsung members that if anyone give proper way then you can accept his solution.
Akshay06
Galaxy M
Jabse Android 10 update kiya hai tabse fast charging not working 4 to 5 hours lag rahe hai
Kishore9
Galaxy M
can you show me screenshot in notification when you put charging
Not applicable
Galaxy M
