Samsung M21 battery drains automatically. Battery drains without use.
(Topic created on: 05-19-2024 07:35 PM)
PuruY
Beginner Level 3
Galaxy M
Samsung M21 2021 edition battery drains very fast. I am not pro user. I charged 100% at morning. Without use I mean zero use battery drains automatically to 40%. Kindly help to resolve the issue.
3 Comments
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Ajay_das
Galaxy M
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
Galaxy M
Check the background activities of apps. Apps like social media, map, email and some games always run in background. Put the unwanted apps to deep sleep.
