Samsung Galaxy M53 5g Bluetooth Connection Issue How to Fix it ?
(Topic created on: 05-21-2023 03:22 PM)
sivavj
Galaxy M
"Updated One UI5",
“After connecting boAt bluetooth headphoneconnecting properly but while playing the video or songs first 30 sec sound come after that it will not hear but song continuously playing.”
19 Comments
Galaxy M
This may be issue with boat headphone.
Tap on 3 dot of my comment and accept as solution 😊
sivavj
Galaxy M
That BOAT headphones 🎧 works properly other mobiles without any issues. Only not working Samsung galaxy m53 5g after one ui 5 update... I'm checking also Samsung m21 mobile headphone works good
Galaxy M
Try reset network setting , this will fix your Bluetooth issue.
sivavj
Galaxy M
network rest and mobile hard reset all options tried two times but nothing happened... any other idea 💡 How to solve this ??
Galaxy M
Have you updated to feb sequirty patch,
this issue slowed in android 13 one ui 5 (1 feb 2023 secuirty patch level )
I am also facing this issue before 1 feb secuirty patch level
sivavj
Galaxy M
See this bro I'm also Updated Feb 1 security patch levelScreenshot_20230521_220139_Software update.jpg
Galaxy M
But in my case after software update this problem totaly slowed
Galaxy M
In my m53 5g device
sivavj
Galaxy M
Me also use Galaxy M53 5g.. how you fixed this problem in your mobile
