Samsung m34 5g Bluetooth device connect problem
(Topic created on: 05-15-2024 07:03 PM)
koushikDey
Galaxy M
My Samsung m34 5g mobile same time Bluetooth device not connect. Many times disconnect Bluetooth.
11 Comments
pankaj21
Galaxy M
Same problem in my M34 5g
koushikDey
Galaxy M
Thanks
goodthings
Galaxy M
Kindly reset all settings of your's device in general management settings then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
koushikDey
Galaxy M
All time copy paste..
I am also report again comment..
computer14
Galaxy M
No issue for me
koushikDey
Galaxy M
You are a lucky person..
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue by given link. https://www.samsung.com/in/support/mobile-devices/how-to-fix-bluetooth-connection-problems-with-your....
Reset app preferences: Settings > Apps > More option > Reset App Preferences.
Kindly try to connect your device with "other devices" and check.
Clear cache: Settings > Apps > Menu > Show system apps > Search
and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset settings: Settings>General Management>Reset> Reset all settings to their default.
Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
Please copy the below-mentioned URL link and paste it into your web browser for troubleshooting steps.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
koushikDey
Galaxy M
Already mobile all reset.. not solved
aarvisingh
Galaxy M
Semsung gelexA35 me other Bluetooth device not connect problm
