M52 5g Battery drain
(Topic created on: 01-05-2024 08:24 AM)
harryl5555
Galaxy M
My phone battery is drained without using. I don't know what is happening with my phone.
6 Comments
VedantA52s
Galaxy M
Maybe due to some heavy apps in background or some service. It may also be the work of some malicious application.
harryl5555
Galaxy M
How can I check that
AJAB_MORIA
Galaxy M
Back up all your data and Do factory reset!(If possible).
harryl5555
Galaxy M
It takes time. I don't have any backup storage device. Thanks for your suggestion
cs_member10
Galaxy M
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Veryna
Galaxy M
My M52 has 15 green lines in full brightness after the recent update and that is causing a quick battery drain. Samsung refuses to replace the screen for me and other users as well even though this is a defective model that was released without adequate testing. Lesson Learnt: Don't ever buy a Samsung product again. We all learn it the hard way. Samsung is the worst.
