M34 Usb not detected and charging not working with Samsung cable and adaptor
(Topic created on: 06-05-2024 10:22 AM)
AshokYou
Galaxy M
M34 charging not working with Samsung cable and adaptor.
Updated the phone didn't work.
5 Comments
ĎÈXȚÈŘ
Galaxy M
If your M34 isn't charging with a Samsung cable and adaptor even after updating the phone, there might be an issue with the cable, adaptor, or the charging port on your M34. Have you tried using a different cable or adaptor to see if that resolves the issue?
AshokYou
Galaxy M
Yes I did try different samsug cable it doesn't charge wit any adaptor but only charged 2 times when connected to Laptop.
Now it's not charging via laptop as well.
aforarnesh
Beginner Level 4
Galaxy M
Also have been facing same issue in my Galaxy A53 5g since two days. Care is saying to replace the charging board, service worth 1500
cs_member10
Galaxy M
Dear Samsung Member,
As you have mentioned that you did try different Samsung cable it doesn't charge with any adaptor, we request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Sujin007
Galaxy M
Same case with my Galaxy M34 as well. It started happening after the latest update to One UI 6.1. The phone does not charge and drops the charge even when it is plugged.
