04-22-2024 07:07 PM (Last edited 04-26-2024 06:58 PM ) in
Galaxy M- Mark as New
04-23-2024 07:17 AM in
04-26-2024 06:59 PM in
04-26-2024 09:09 PM (Last edited 04-26-2024 09:10 PM ) in
04-23-2024 08:22 AM in
Galaxy MDear Samsung Member,
Check device network mode settings: Settings> Connections> Mobile networks> network mode SIM1 or SIM2> Select network mode(set device network mode as 5G/LTE/3G/2G (auto connect) mode.).
Check network operator settings: Settings> Connections> Mobile networks>Network operators> Select automatically> OK> Registered on the network.
Note: We recommend setting device network operators as automatically.
Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
Reset settings: Settings > General Management > Reset.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
