M Series compatability issues with Samsung Smart Switch for Mobile in google play store
(Topic created on: 01-26-2020 01:37 PM)
mathew3
Galaxy M
Hello Samsung experts I recently purchased Samsung Galaxy M30 in India as it is made & sold for Indian SIM's. During migration of my data from old phone to this device, I tried to search for Samsung Smart Switch for Mobile in google play store from M30 and could never find. Then google search, I tried to search the same software from M30 and it threw the error that "Your device isn't compatible with this version".. Tried to contact Samsung Developers
Sent: Thursday, January 23, 2020
To: sswitch.cs@samsung.com <sswitch.cs@samsung.com>
Subject: Re: Samsung M30 incompatible with Samsung Smart Switch Mobile
Hello Smart Switch Mobile Support Team,
Thank you for the quick revert.
Would like a further clarification on
  1. If it is only with Samsung M30 that is incompatible with the official Samsung Smart Switch Mobile app?
  2. Or Is it the whole Samsung 'M' Series mobile having this incompatibility issues with Samsung Smart Switch Mobile app?
  3. Why such incompatibility issues remain unfixed between official original Samsung phone M30 and official Samsung Smart Switch mobile app, when the phone is running the latest Android versions much higher than the comparable phone and android versions?
  4. Now that only one app is identified in the short run, can I find or gather the list of incompatible google play store apps/ softwares with my Samsung M30 or in general Samsung M Series?
Regards
Appreciate if some one responds to the query.  While conversing with a mobile guy, he was mentioning that M Series is only incompatible with one software but multiple. But there is a workaround to download from Samsung Store.
Also if you could refer to any official article from Samsung.
Thanks
Matt
16 Comments
Š
Galaxy M
Some Samsung apps require Knox, a chip level security, which is not available in M series. Those apps cannot be installed.
mathew3
Galaxy M
Any official technical documents from Samsung that you can share.
If this is the case, why Samsung Team is not responding to my concerns with a straight forward response.
Sciphile
Galaxy M
Samsung has moved most of its app to Galaxy Store, here is a link to the Galaxy store version of Smart Switch, this will work definitely
http://apps.samsung.com/appquery/appDetail.as?appId=com.sec.android.easyMover
mathew3
Galaxy M
Thanks. I see that it applies only to M Series while other series remains intact.
Sciphile
Galaxy M
No buddy, even I own a M30s, smart switch works fine, there are only few apps that won't work in M series devices.. like Samsung pay and Goodlock
Samsung_hsKndKO
Beginner Level 3
Galaxy M
That worked. Thanks a ton.
Dareheller
Beginner Level 3
Galaxy M
Thanks Mate..... Worked like a charm...
Samsung_z8CxHIK
Beginner Level 3
Galaxy M
Great, thanks Man, your link worked for me.
Dëv
Galaxy M
Thanks @Sciphile
