Low volume solution πŸ˜‰
(Topic created on: 10-27-2021 01:58 PM)
evoiscute
Galaxy M
We all know the single speaker in M series devices are average quality and give a low volume output...
Try this to solve this issue πŸ‘‡πŸ»
But I'll not be responsible for anything try at ur own risk πŸ‘πŸ»
Download "wavelet" form this link
Install the app and open it's setting by clicking the setting icon below you'll see a setting menu like this.
Enable the legacy mode and set buffer size to 4096 samples.
Turn on the limiter option and set post gain value to 4.0 or 4.3, more than this value can cause damage to speakers "
Don't touch any other setting unless u know the use of them πŸ‘πŸ»
Now Enable the graphic equalizer and choose
v-shaped for a better audio output.
V-shaped for better quality.
Vocal boost for loudness.
Other you can try by your own preference 😊
You're all done πŸ˜„ now see the performance of ur speaker
8 Comments
Galaxy M
nice but speaker are good in m series...as i see.
Edwin7878
Galaxy M
Not good bro .
Its just average mono speakers compared to the competitor's mono speakers
Galaxy M
okay i will definetly check
SrajTech
Galaxy M
Buy my A50s and m30s sounds much better than redmi note 9 and realme 8
Only m51 mono speakers are not good
Edwin7878
Galaxy M
I meant mainly m51 bro .
Mono speakers of samsung are not much loud but the audio quality is good
SandipEnigma
Galaxy M
No, they are not. They are very low
Galaxy M
Atleast they have dholby atmos!!
SandipEnigma
Galaxy M
But that is only for headphones. People do not use headphones all the time. Their speaker volume is also very low.
