I'm facing this problem what should I do ? screen color problem
(Topic created on: 10-06-2024 10:35 PM)
Subhajitdey02
Galaxy M
3 Comments
goodthings
Galaxy M
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
cs_member10
Galaxy M
Dear Samsung Member,
We request you kindly share the log file and elaborate on your concern in detail. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appriopriate issue category> Type your query and send.)
