Guys I found a solution for auto restarting issue in exynos 9611
(Topic created on: 01-25-2022 05:06 PM)
harryl5555
Galaxy M
Solution to auto restarting in exynos 9611
Try factory reset after that put your phone in power 🔋 saving mode, shown below. And you have to control the your usage pattern. Do not throttle the cpu with high confugurated apps, like games and editing apps.
This trick works for me, if it works for u share with ur friends. And comment below.
Power saving setting
13 Comments
Tikunwengsu
Galaxy M
If you are facing this problem then go to setting > Battery and device care > then click on upper right corner three dots > and then see Automation.
Turn off these settings maybe in your device it turns on
Maybe helpful.Screenshot_20220125-103134_Device care.jpgScreenshot_20220125-103144_Device care.jpg
WalkieTechie
Expert Level 4
Galaxy M
Bro he has not shared a problem, he has shared a solution in this post.
WalkieTechie
Expert Level 4
Galaxy M
Great.. hope it helps others facing the same issue.
rahul2006
Galaxy M
Till now i have not faced such issues
Tikunwengsu
Galaxy M
Same here also
harryl5555
Galaxy M
U r lucky too
harryl5555
Galaxy M
U r lucky bro
rahul2006
Galaxy M
Thanks bro
Galaxy M
No one is perfect solution.
They supplied faulty motherboard.
I throw out my M31 after 14 months only because of phone is dead.
Instead of repair,purchased new phone.
