Galaxy m42 auto restart problem and wifi Hotspot not working.
(Topic created on: 09-07-2024 01:08 PM)
NilamaniSa
Galaxy M
Galaxy m42 auto restart problem and wifi Hotspot not working. When ever I'm switching off and on my device than my phone is stock on or hang on logo and whenever I'm turning on wifi and Hotspot the problem is happening.
cs_member10
Galaxy M
Dear Samsung member,
Galaxy device auto restart issue: kindly follow the easy troubleshooting steps which might help to solve the issue.
Kindly use genuine Samsung charger.
Note: We always recommend to use genuine Samsung charger for charging your device.
Disable auto restart function
There are two methods to disable auto restart function
Method 1: Navigate to apps screen and tap on Settings>>Tap on General management>>Tap on Reset>>Disable Auto restart (if enabled)>>Auto restart disabled.
Method 2: Go to "Settings">>Tap on "Battery and device care">> Tap on Three dots>> Tap on "Automation">>Disable "Auto restart at set times" if enabled
If you are facing this issue after installing any new application, then uninstall that application.
Please follow the below steps:
Navigate to apps screen and tap on Settings>>Tap on Apps>>Tap on desired app>>Tap on Uninstall>>Tap on OK.
Galaxy device Wi-Fi issue: https://www.samsung.com/in/support/mobile-devices/how-to-troubleshoot-a-galaxy-phone-that-wont-conne...
Galaxy device hotspot issue: kindly perform some basic steps which should resolve the issue.
Disable the data saver:
Path: Settings > Connections >Data usage > Data saver > Disable data saver (if enabled)
Reset network settings:
Path: Settings > General Management > Reset > Reset network settings
Reset settings:
Path: Settings > General Management > Reset > Reset all settings
Galaxy device hang issue: https://www.samsung.com/in/support/mobile-devices/why-is-my-phone-slowing-down-and-how-can-i-speed-i...
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
You can reset your device by following the steps.
Samsung Customer Support.
