Charging problem with charger connected to power socket, charges only with laptop usb power.
(Topic created on: 08-24-2021 09:52 AM)
sc30
Galaxy M
Problem Statement: -
My SAMSUNG M30 mobile is not charging when trying to charge with the SAMSUNG charger provided with the phone when connected to power socket. But when I charge it by connecting the phone to USB port of my laptop it charges.
Detailed Description: -
1. Initially the phone wasn't charging with the default charger when connected to power socket. Then it was charging only when connected to USB port of the laptop.
2. Later it wasn't charing event when connected to USB port of the laptop.
3. Now only with SAFE MODE ON, the mobile charges ONLY when connected to USB port of the laptop.
4. It doesn't charge with the default charger when connected to a power socket.
Solution Tried: -
1. Power ON the device on SAFE MODE. Result: - do not charge when connected to a power socket, charge when connected to USB port of the laptop.
2. Power Off and try to charge the mobile.  Result: - do not charge when connected to a power socket, charge when connected to USB port of the laptop.
Could You please help to solve the problem ASAP?
10 Comments
Not applicable
Galaxy M
One of Software problem .
sc30
Galaxy M
Any idea how I could solve the software problem, in case there is any.
Lekshmanan
Expert Level 4
Galaxy M
Check With Other Brick. If Charging Buy A New Samsung Charger Brick From Samsung Authorized Store.
sc30
Galaxy M
I've already tried using another SAMSUNG charger and that is NOT charging it. And my charger charges other SAMSUNG mobile. So, the problem is NOT with the charger.
AlphaTrion
Galaxy M
Probably charging port or software issue. Since these are the only 2 other things that can cause it apart from the charger.
Lekshmanan
Expert Level 4
Galaxy M
I Think Problem With Port.
Lekshmanan
Expert Level 4
Galaxy M
Visit Service Center
sc30
Galaxy M
Can I try anything else at home before going to the service center? Can anyone help here?
I found out another thing, it's charging at safe mode with the charger connected to a power socket when I'm using a charger of lower power.
Basically, It's charging only at Safe Mode with a lower capacity/voltage/power charger.
Galaxy M
Dear Samsung Member,
We apologize for your inconvenience. Please visit this mentioned link to resolve your charging related issue: https://www.samsung.com/in/support/mobile-devices/battery-not-charged-charging-related-issue/#:~:tex...
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
