Resolved! Solved
Camera Light sensor battery drain
(Topic created on: 06-13-2019 11:47 AM)
AnuragHarsoraJain
Galaxy M
Cameralightsensor consume more than half of battery after pie update Samsung m20Screenshot_20190613-114237_Settings.jpg
Resolved!
37 Comments
DhruvShah2006
Galaxy M
Never going to take samsung again
Samsung_tPF6lNv
Galaxy M
i think i found a solution here guys.
Mine is A30. I noticed that when i rum the dark mode with battery saving OFF i don't get battery drain and no camera light sensor appear on the battery stats.
Aven1
Galaxy M
Same problem. À50
Ameenex
Galaxy M
You hot it at 59%....I have it at 102%😢
kdb13
Galaxy M
I think it also has something to do with Always On Display as it also uses ambient light to increase or decrease its brightness at night. So turning off AOD might also help.
lightguy48
Beginner Level 4
Galaxy M
I have this same issue - I have an XCover Pro and for the longest time the adaptive brightness did not work, now they fixed it sucked down 65% of battery yesterday!!
Samsung fix this!!
salekuzzaman
Galaxy M
How can i solve this Problem Screenshot_20221114-170135_Device care_104672_1668423695.jpg
arunpravin16
Galaxy M
Way to solve camera ligjt sensor problem in samsung galaxy m21
