Resolved! Solved
Camera Light sensor battery drain
(Topic created on: 06-13-2019 11:47 AM)
AnuragHarsoraJain
Galaxy M
Cameralightsensor consume more than half of battery after pie update Samsung m20Screenshot_20190613-114237_Settings.jpg
sidbhokare
Galaxy M
M series uses virtual light sensor....which means they device front camera as light sensor...that's why Battery drains...but you can avoid that by turning off adaptive brightness....You can accept my solution by just clicking 3 dot on this comment...
37 Comments
viahwash
Galaxy M
yes,It is right
sidbhokare
Galaxy M
GalaxyM20Phone
Galaxy M
No. Galaxy M20 actually does have a light sensor. Refer to page 11/152 of the phone manual here.
Here is the schematic:
galaxy-m20
Ijkmoises
Beginner Level 3
Galaxy M
it works !
Lokanath1994
Galaxy M
No this is not the solution, its just a workaround.
How do I fix this, I need adaptive brightness feature.
TheDitached
Galaxy M
so, is there any way to decrease the battery drain?
RKJ77
Galaxy M
m30s has major battery drain issue with camera light sensor
..50% battery wastage.... looks like product defect or faulty last android software update for model 30s
SHIVA003
Galaxy M
is this solved ? because I happen to see this issue nowadays with my phone
aaabbbcccdddeee
Galaxy M
Same prblm facing Samsung galaxy 31
