09-06-2024 11:06 AM in
Galaxy MSolved! Go to Solution.
09-06-2024 11:52 AM in
Galaxy M- Mark as New
09-06-2024 11:53 AM in
09-06-2024 02:33 PM in
Galaxy M
09-06-2024 04:46 PM in
Galaxy MDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
