Battery Drain issue
(Topic created on: 12-30-2021 07:08 PM)
LittleMiku
Galaxy M
I am using a Samsung M31 and I am facing the battery Draining issue for some days..even though I don't use much heavy apps or games...I have a 6000mah battery still have to charge my phone twice a day from some days...any reason why this is happening... Earlier I use to charge once a day and it was more than enough for the entire day
6 Comments
savage_arpit
Galaxy M
Check if there's any app which is causing this.
LittleMiku
Galaxy M
Checked and blocked ...but still goes on...I think the climate is an issue...I live now in a hilly area where temperature gets down very rapidly...that may be causing it
savage_arpit
Galaxy M
Yes it can be the reason.
ShantanuBarve
Galaxy M
I'm getting battery problem too.....specifically after the update
LittleMiku
Galaxy M
True... samsung knowingly doing this ...coz it was fine 1 yr ago..and since it completed 1yr everything's got slow
cs-member13
Expert Level 4
Galaxy M
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
