Battery Drain and Overheating Issues with Samsung Galaxy M35 5G
(Topic created on: 08-01-2024 08:27 PM)
SHEIKBAVA
Beginner Level 5
Galaxy M
I recently purchased a Samsung Galaxy M35 5G about a week ago. Unfortunately, I've been experiencing some issues with the device.
1. Battery Drain: The battery seems to be draining unusually fast even with normal use. I haven't been using any heavy applications, yet the battery life is significantly shorter than expected.
2. Overheating: The phone gets noticeably warm, especially during charging. This is concerning as it might affect the overall performance and longevity of the device.
Has anyone else encountered similar issues with the Galaxy M35 5G? Are there any recommended solutions or settings adjustments that could help mitigate these problems?
20 Comments
sidharth3768
Galaxy M
This is completely normal with new devices.Your phone will take some time to learn your usage pattern and everything will be fine after that.
goodthings
Galaxy M
Your's device is very new so please give it's some time. After some time and after some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
Oldy47
Galaxy M
Does your phone heats in following things?
One idle /not in use /if AOD is on
Using with 5g
Using in sunlight /max brightness.
Using apps not gaming etc
Oldy47
Galaxy M
Why do we need to update every single app ? Like nobody use every single app on phone or do we ?
And with faulty updates from samsung and others, One might try to not update even the Android system because of greenline issues.
Oldy47
Galaxy M
Bud the apps you mentioned doesn't come under system app category, just because you can't uninstall them don't mean anything. They are samsung apps not the android for core functioning.
Regarding Update - Updating them won't make them good but sometime worse.(because it's droid).
I think you took it seriously when somebody told you that updating every app on phone is the best way to make phone efficient.
Oldy47
Galaxy M
Yes absolutely your right.
How I didn't get it why iam so dumb why.
Why couldn't I see that samsung shop is for shopping from their store.
Meta is social platform
Meet A video calling app
Google a search engine
Onedrive Microsoft cloud
From your technical pov these and many more in other brands are system apps but are they really . Even If I Disable one or all of them from device android system won't even care because it's not important for Android but for samsung and same goes with other brands .
Try again :)
Sameer
Galaxy M
New phone definitely needs some time .
Making few changes can enhance battery life to a greater extent ..
Making the following changes as shown in the video ...wait for few weeks for the phone to study the usage patterns and you will see an improvement in battery life
https://youtu.be/DXM7pdW5a-w?si=cXv4W6zVL3JvVBqp
Also make your phone run 2x faster.
https://youtu.be/pgNi1Pmua3c?si=HvJhiGglU77saHG9
A lot of exclusive content coming up so do subscribe to my channel for all future updates
ch4A
Galaxy M
It may damage over heat due to duplicate materials
