Resolved! Solved
Battery Drain After Upgrading to Android 14 and One UI6
(Topic created on: 01-14-2024 12:12 PM)
CharlesJudsonMoses
Galaxy M
I Use M34 5G. Before Upgrading To One UI6. The Full percent battery (100%) 🔋 lasted for About 23hrs. But now After Upgrading to One UI6 The Full Percent (100%) Lasts for Only 13hrs.🔋 is everyone Who Upgraded to One UI6 Experiencing the Same Situation?
FYI -
(UI 5.1) = I go to college and come back at 6PM and By the time it's 10PM I am Still left with 40% Charge. 🔋
(UI 6.0) = The same above situation with same Timings and I am Left With 20% Charge. 🔋
And the Other thing that I observed After Upgrading One UI6. Even though I am not using the phone. The Charge depliets. from 100% to 97%. Or 80% to 77%
Resolved!
19 Comments
BlueStarn
Galaxy M
Galaxy M
Galaxy M
I Use Widgets and pods a lot. So I will try to Stop them for a week and see if it's any better. 😇👍
BlueStarn
Galaxy M
Sure try it out, hope it works
umesh30
Galaxy M
Smartphones need some time to calibrate newly upgraded OS...
Once done, it will automatically optimize according to your usage pattern...
Don't use fast charging mode regularly. It really impacts on battery life.
Put heavy app in deep sleep app list.
Turn the 'Nearby device scanning' option off if you don't use any other samsung (ecosystem) or any device for connectivity like wireless earbuds, SmartTag, IoT device, etc.
ramkd003
Galaxy M
I didn't receive ui 6
Galaxy M
Device?
ramkd003
Galaxy M
M 34 5g
Galaxy M
Once go and check software update. And click on download and install. 1705311882362.jpg
Galaxy M
M14
