USB not working in J7 Max.
(Topic created on: 08-01-2023 06:10 PM)
imranshan6
Galaxy J
Hi,
I am using Samsung Galaxy J7 Max for the past 7 years. Suddenly my USB stopped working few years. I didn't do anything cause I didn't need it. Now I am in a need of transferring few files to my laptop and also need to debug my mobile (USB debugging). Please help me with this issue.
Note:
1. I tried changing USB cables so many times. Those cables are working with other devices.
2. With same cables I can able to charge my mobile.
15 Comments
Galaxy J
You need to get your device checked in this case if you want data cable to work. If not you can try FTP apps from play store to retrieve your data wirelessly.
imranshan6
Galaxy J
Sure I would try. Thanks.
cs_member10
Galaxy J
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
1. Settings>>>Developer option>>Default USB configuration>>>USB tethering>>Disable it.
2. If the issue still persists then check the USB connection. Perform interactive checks through Samsung member apps:- Path:- Samsung member>>>Get help>>>Interactive check>>Charger/USB.
3. Also make sure that you are using a genuine Samsung charge.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
imranshan6
Galaxy J
Hello,
Sure, I would try the above mentioned solutions.
Thanks for the response.😊
cs_member10
Galaxy J
Dear Samsung Member,
As per your query, as you have already done the possible troubleshooting steps on your device, we would request you kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Kanhaiya8989
Beginner Level 3
Galaxy J
Not supported usb
