J7 pro Problem
(Topic created on: 10-20-2017 02:11 PM)
mstrange
Galaxy J
In my j7 pro sometimes back softkey is not working. Phone lags.. please provide some update to fix this.....
9 Comments
Anon
Galaxy J
i too facing the same issue on my j7 pro
mstrange
Galaxy J
Anon in my j7 pro, when headphone inserted there is no headphone sign/icon shown in status bar... what about yours?
sraarav
Galaxy J
yes...also fix wallpaper colour change when i set as a wall paper
Anon
Galaxy J
yeah i too noticed that
Anon
Galaxy J
yeah there no headphone sign but the headphone is working perfectly fine.so i dont think its an issue.
Anon
Galaxy J
admin_
Galaxy J
Thank you for your query. We would like to inform you that smart phone can be hanging, freeze , lagging and slow with many reasons like install any third party application (e.g. Antivirus, Call recorder, clean master, battery booster, battery saver etc.). It can be harm full for any smart phone. Samsung never recommended any third party application. It is harmful for device. So we would suggest to you kindly uninstall mentioned above application.
Kindly checks by following below mentioned steps for overcome the issue of Hanging:
1) Utilization of maximum storage from internal memory, may hang your device. For that we recommend you to delete some of the downloaded data from your phone for better performance as internal space should be 20% free OR’ transfer data to SD Card via My Files.
(Phone Application>>My Files>>Select Multimedia Data>>Press More>>Click Move>>Select Location of SD Card>>Click Move Here).
2) Menu> smart manger>clear ram.
3) Stop running application (Setting >>Application Manager>>Running>>Stop All Downloaded Application When Not Using).
4) Check all the applications are closed by using the Task Manager option.
5) Scan SD card and then check.
6) Software update handset (Setting>>Software Update>>Download update automatically>> update using 3G/4G or Wi-Fi connectivity.
7) Go to setting>General>Application Manager>All>Tap on 3 dots (right top) ‘Reset app preference’.
If still issue persists, we request you to operate the device in ‘Safe mode’ as steps are mentioned below:
1. You need to restart your handset by pressing power key.
2. Then, when Samsung logo appears on the screen long press volume down key and keeps pressing it.
3. You will see a safe mode label at bottom left side, when your handset will be entered into safe mode.
4. To exist safe mode kindly restarts your device.
Anon
Galaxy J
samsung admin,
i have already read this .I tried all the above steps and i have visited the service centre.But still i am facing this issue.plz fix this freezing issue through a software update.
mstrange
Galaxy J
Dear Admin thanks for your reply.. why there is no sign or icon shown when headphone is inserted in my j7 pro?
