Wifi Network Range Problem
(Topic created on: 09-03-2025 09:50 AM)
abhisesh
Galaxy F
There Samsung Moderator
One of the most important problems of samsung galaxy f15 device
The problem is Wifi Range is to short
Please fix this problem
Thanks you
4 Comments
goodthings
Galaxy F
Kindly complaint to Samsung customer care support through Samsung Members App as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy F
You're welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
As per your query, we would like to suggest that you contact your network service provider directly. They will be able to provide you with the exact information you need regarding this matter.
nickshe
Galaxy F
Why is my wifi and hotspot range too short? It only about a meter
