F23 Auto restart problem after recent update, WIFI, HOTSPOT, not WORKING,
(Topic created on: 06-24-2024 02:17 PM)
Adiddd
Galaxy F
After recent update my Samsung f23 5g is not working properly. Phone is automatically restarting and freeze on optimising app. WIFI, hotspot, Bluetooth not working. On using freeze with continuous Beep sound and turn off. Upon restart again same problem since 1 week. Battery also drains fast. I did factory reset but in vain.
16 Comments
Arya111
Galaxy F
Visit Samsung Service Center.
Prajwal545
Galaxy F
They are saying to replace motherboard which costs ₹10000😭
Galaxy F
Motherboard cost 7,020/- GST+labour charges extra. If we calculate around 1k extra (gst& labour charges) it would cost 8,020 then how it cost 10k? Did you approached samsung authorised service centre? If so please ask them about this.1738230886548.jpg
Prajwal545
Galaxy F
Yes, I approached Samsung authorized service centre and contacted Samsung customer care they said that replacing motherboard costs around ₹10000 🫠. Even if it costs 7k I'm not ready to pay 7k for a phone which is not even worth 7k. So I'm using my phone without WiFi, Hotspot and Bluetooth and getting random restarts while using phone from June 2024🥲. Thanks for researching about repair cost😊
Galaxy F
Bro did you updated device software& Google play system update to the latest version?
Prajwal545
Galaxy F
Yes I updated but no changes
goodthings
Galaxy F
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy F
Your's most welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
As you are facing multiple issues on your device, So, we would request you kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
