Connection problem or invalid MMI code
(Topic created on: 03-15-2024 12:39 PM)
Bishal85
Galaxy F
I'm using Galaxy F14 5g .
From several weeks I'm facing weired problem.
While I'm entering USSD codes like *#0*# or *#06# or *#07# , always shows that 'connection problem or invalid MMI code '
Please tell me why it is occurred and what is the solution?
I'm very worried about it .
7 Comments
99Case
Galaxy F
The auto blocker must be on under security settings. Disable the same and it should work post restart.
Bishal85
Galaxy F
Thank you so much , it working .
jakaria53
Galaxy F
I have tried this setting many times but my problem is not solved
99Case
Galaxy F
No worries. Happy to help..
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we want to inform you that kindly turn off the Auto Blocker by the given steps, if the codes not working
Settings > Security and privacy > Turn off Auto Blocker.
Bishal85
Galaxy F
Very very Thanks . It's working
jakaria53
Galaxy F
