Resolved! Solved
Battery drain issues
(Topic created on: 09-03-2025 10:31 AM)
krrish06
Galaxy F
After august security update in samsung galaxy f15 5g battery drain a lot .
Fix this problem samsung community
2 Solutions
BiRdMaN
Galaxy F
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
goodthings
Galaxy F
Kindly complaint to Samsung customer care support through Samsung Members App as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
6 Comments
BiRdMaN
Galaxy F
krrish06
Galaxy F
Thanks
goodthings
Galaxy F
krrish06
Galaxy F
Thanks
goodthings
Galaxy F
You're welcome.
cs_member10
Galaxy F
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
