a50 android 11 update edge led notification light missing
(Topic created on: 03-09-2021 01:46 PM)
Brahmarao
Please add this option please
18 Comments
Brahmarao
thq bro
If satisfied with my response then click at 3 dots near my above comments and accept them as solution to help others 👍
Ehsank
now it is under notification >brief pop up
KV404
do you know how to install edge lighting + in a50 or add more lighting styles?
Ehsank
but now its received edge lighting style, if you are saying edge lighting+ then you xan try by apk mirror
KV404
I tried bro but it's showing update the app but I downloaded latest version 1.0.28
Edge lighting+ not compatible with android11/UI3.0/UI3.1
Ehsank
first thing is its not compatible but you can try after few days as it need also update after new android
Selvamax
does it coming for call??
