Sound Problem
(Topic created on: 06-23-2025 04:37 PM)
Pikhe
Sometime when video is played in apps like samsung video player or youtube the voice doesnt come evn after increasing volume it comes after reopening of applications. Does anyone have solution for this as this thing is going on with my two to three galaxy devices even after visiting service center?
5 Comments
AvishekG
🔧 1. Turn OFF Dolby Atmos (if ON)
Go to Settings → Sound & vibration → Sound quality and effects
Turn Dolby Atmos OFF
Also disable Adapt Sound if it's enabled
> Users have reported this fixes audio inconsistencies in multiple apps.
🔄 2. Clear App Cache/Data (YouTube, Samsung Video, etc.)
Go to Settings > Apps > [App] > Storage
Tap Clear Cache and if needed, Clear Data
(Don’t worry — YouTube will resync your account after.)
🔕 3. Disable “Mute All Sounds” Accessibility Feature
Go to Settings → Accessibility → Hearing enhancements
Make sure “Mute all sounds” is turned OFF
🔗 4. Reset App Preferences
If this issue is widespread:
Go to Settings > Apps > Menu (3-dots top right) > Reset App Preferences
This will reset notification and audio settings across all apps
Pikhe
I think restoring of phone does these things but still its the same
AvishekG
Samsung is aware and working on this — the One UI 8 / Android 16 update is expected to bring more audio stability fixes.
Pikhe
What about mobiles not receiving one ui 8
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
