06-10-2025 08:18 PM in
Galaxy A- Mark as New
06-10-2025 08:20 PM in
06-10-2025 08:29 PM in
06-10-2025 09:11 PM in
06-10-2025 10:58 PM in
06-10-2025 09:08 PM in
06-11-2025 09:47 AM in
Galaxy ADear Samsung Member,
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
