Samsung blur and focus problem issue quality problem camera on samsung A55
(Topic created on: 03-28-2025 01:02 PM)
kranthisuresh123
We need camera upadate
4 Comments
goodthings
goodthings
Your's most welcome to here.
AudioJack35
Go to social media and tag #Samsung official accounts and  describe your issue to get their attention
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue. We are taking your feedback regarding this matter and will take it into consideration for future updates.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
