Samsung Galaxy a50s battery drain issues
(Topic created on: 09-24-2020 06:29 PM)
MandarS23
Samsung a50s is the best selling device but , due to his battery proformance it has been very disappointing for us . Even I am charging my cell till 90% to 95% then also I am not getting much backup. Really very disappointed about this.
All tricks an tip are fail on front of this.
Samsung kindly look at matter an solve this.
🙏Your Samsung user🙏
10 Comments
galaxyboi
bro what's your a50s battery backup mine is 8hrs continuous usage for online classes
bro it's camera quality is also degraded after last update
MandarS23
I am not using camera much enough...so I don't know bro .
Ayan2002
bro you are right. its camera sensor is not good. And also problems in software. this phone has heating issues. And battery life is not good.
veer
• Optimise the device using the device care feature.
• When you are not using the device, turn off the screen by pressing the Side key.
• Activate power saving mode.
• Close unnecessary apps.
• Deactivate the Bluetooth feature when not in use.
• Deactivate auto-syncing of apps that need to be synced.
• Decrease the backlight time.
• Decrease the screen brightness
MandarS23
thnxx 🙏
Ayan2002
you are right bro. I have a also samsung Galaxy A50s. And I noticed it. if I show video then battery life is 3/4 hours.
abbishek091
Absolutely right
SrajTech
The only thing is that you have not optimised your settings
Go to device care , battery , then put all google apps, facebook, messenger and other apps you want ,to sleep .
Go to app info and restrict backroung usage.
I am getting 5 hrs+ screen on time, which is more than enough for a 4000mah battery.
i charge till 85 or 90 %
Galaxy A50s comes with 4000 mAh battery but typically under test conditons its only being rated as 3900 mAh. So 8 hrs screen on time continously is normal on a single charge. As battery backup depends upon various factors such as poor network coverage, excessive brightness, background running apps etc. So uninstall third party apps that you don't use often and turn on adaptive brightness so that your phone can adjust brightness according to your comfort. Although battery gets degraded after 3 to 4 years of usage and you may notice degraded battery performance.
