Samsung A50 Speaker and Mic issue / Problem / not Working Solution
(Topic created on: 05-01-2023 10:32 PM)
Jigsleuva
Hey guys ,
I am also samsung A50 device user.
And i am facing this issues for long time
Pls follow my tips and tricks
Do it Your device will work normally
Step 1. Plug your device into Type C Cable
Not for charging purpose
Step 2. Type C cable otherside USB part plug into PC/Laptop or any TV which have USB function.
Step 3. After u can see android file transfer notification on notification panel Then power off your device
Step 4. After u can see charging logo on off screen then u press Volume UP + power button (10 sec)
Step 5. U can see many options but have to select wipe cache and clear cache.
Step 6. You will see Reboot To Bootloader option and then select it using volume up/down button
Step 7. U will see download logo Leave device for process for half an hour
Step 8. After half an hour u can turn on device using press volume down + power button (7 sec)
U will see your device will have working properly
Share this tips to all
Thanks
UdayakumaranTS
Beginner Level 3
Dear Jogsleuva,
Thanks for tips
Followed all the above steps and tried to clear the cache but the problem still remains same.
Thanks
